Why does my controller not charge?
My controller will not charge. Sometimes if you get it just right it will charge for about 4 seconds and then turn back off. What should I do?
It may just be a battery issue. You can replace the battery with the part below. I also provided a guide on how to replace the battery.
DualShock 4 (JDM-030 and Earlier) Controller Battery
Here’s how you can replace your charge port, if necescery. Choose the right charge port for your model controller
产品
$8.99
产品
$5.99
产品
$6.99
指南
难度:
简单
10 - 15 minutes
指南
难度:
中等
25 - 40 minutes
这个答案有帮助吗?
Hi @ajcooke01 ,
Not disagreeing with you but the OP states "Sometimes if you get it just right it will charge for about 4 seconds". I'm wondering if the "....get it just right..." relates to the USB cable connection and perhaps it may be a loose or damaged port.
Your thoughts? ;-)
I haven't had time to get around to fixing it but I am going to this weekend. That could be a possibility as well. If you have a link to a guide that might help me with that it would be much appreciated!
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 94
