跳转到主内容
Repair guides and support for your Samsung TV.
2614 个问题 查看全部
Vertical lines on the side of my tv! Please Help!
I have vertical lines on my TV
(samsung s60fh-yb03), i’ve tried nudging parts on the T board
and removing the flexes
, however when I remove each flex I noticed that it removes a portion of the screen horizontally whilst the lines are still visible vertically on the rest of the screen, so I don’t think i’ve been messing with the correct flexes. I’ll attach pictures of the screen, the flexes i’ve been messing with and the T Board. Thanks for your help!
Added more pictures as requested
Update (10/11/2018)
@oldturkey03 added more pictures as requested
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Was the display hit or dropped? This is very common for a broken LCD panel.
完成的
添加一条评论
2个答案
最有帮助的答案
@calskius
double check your model number. It appears as if you gave us a screen model not a TV model. This is a plasma TV and thus does not have a T-con board. You a pulling the wires of your YSUS boards and therefore you are seeing the results. It could be a sustain board error (Z or X sustain board) but we need to see more of your boards and a proper model number. Post some good pictures of all of your boards and the wiring layout with your question so we can see what you see. Use this guide 在已经存在的问题里加入图片 for that
这个答案有帮助吗?
得分 1
添加一条评论
Slap the back where the lines are until the screen comes back This worked for mine . “if this works its not a permanent fix.”
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
callen dale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 263
