跳转到主内容
Guides and support for various television (TV) brands and styles.
9054 个问题 查看全部
Where can I find this blown thermistor?
My tv clicks when I plug the power cable on, but when I press power, the 'Lamp' , 'Timer' and 'Standby' Lights all blink in unison. I opened up the back and I am seeing a blown thermistor on the power supply board, on it is written 'KL 15L 5R1' and on the board where it is soldered is printed 'GT804' and 'NT802S'. I want to change the blown thermistor instead of buying a whole new power board for $100+, where can I find the thermistor part #NT802S in the US?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Ryan, the values are taken from the manual and thus should help you to find a US supplier. Try Mouser.com or Digikey.com as well as many others. What's wrong with the shops in Australia ;-) like this one
Code No. Description ; Specification
1404-001045 THERMISTOR-NTC;4.7ohm,15%,2900K,35.0mW,T
这个答案有帮助吗?
得分 1
1条评论:
I found a supplier that has one with:
Resistance@ +25'C = 5ohm +/- 20%
Max steady state current = 5 amps
Resistance @ Max Current = 0.1 ohm nominal
Is this close enough?
完成的
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 4,505
