跳转到主内容
加入维修社区 - 创建账户
有关 Frigidaire GLRT183TD* 的维修及补充信息。这是一款 2004 年推出的顶置冷冻柜冰箱,配有自动除霜系统和防凝露加热器开关。本页面涵盖型号匹配 GLRT183TD* 的相关信息。
Why my fridge won't run
I bought a used frigidaire refrigerator, model # GLRT183TDWH, it worked and was cold when I bought it. The gentleman said to lay it down in the bed of my truck for transporting. When I plugged it in it ran for about 30-45 seconds then stopped. The lights are working but it's not running.
I don't have the money for another fridge. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The gentleman does not know what he is talking about.
Normally it is ok to transport a refrigeration unit in any orientation. The problem arises when it arrives at its final destination. The refrigeration unit is designed to operate only in the upright position. This has to do with the way refrigerant and lubrication oils settle inside the unit when it is turned off. The system is designed to leak down after it is turned off, so that when the it starts again, the compressor can start easily due to the low pressure on the compressor side of the system. If the unit is started soon after righting it, or while it is on its side, refrigerant may build to high pressure levels immediately upon startup. This is a good way to burn out your compressor. In short, there is no issue with transporting it that way, but it is always recommended to let it sit upright for at least a day before attempting to start it.
这个答案有帮助吗?
得分 2
添加一条评论
Chamber leak ho gaya
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dana 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 373
