跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
“Service Battery” – how can I disable my Battery
Hello everyone, my battery is defected, I have the warning 'service battery’ which means I need to change the battery asap. However I have issues with Apple and they are not fixing it for free - even though it is classified as a defected macbook pro - Anyways right now I don’t want to use the computer while I have the warning sign…
I am okay with using the computer plugged in all the time. What I want to ask is, is there any way that I can disable the battery? So I won’t be harming my computer, I just don’t want it to function it at all…
PS: I try to buy a battery from ifixit but it is not possible for them to ship it to my country… so sad, if anyone knows another good company that sells macbook battery I would be so happy to hear that
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Have you contacted Corporate Apple directly
13-inch MacBook Pro (non Touch Bar) Battery Replacement Program
https://www.apple.com/support/13inch-mac...
What country are you in and did you go to an Apple Store or an Authorized Service Provider?
这个答案有帮助吗?
得分 3
添加一条评论
Well, you are going to experience performance drops significantly but if that’s what you wish, one answer coming right up!
Frankly I would just remove the battery in general and store it in a well ventilated place. You can remove the battery with the guide below, and I also highly recommend you buy the adhesive remover too so you do not risk tearing or puncturing the battery while attempting to remove the battery.
替换MacBook Pro 13‘’2016年末期带功能键版本的电池
iFixit Adhesive Remover
Update (10/05/2018)
This sounds like a personal question but if you don’t mind, which country do you live in? I am asking this so I can see if I can source you a battery that can be shipped to your country.
iFixit Adhesive Remover图片
产品
$19.99
这个答案有帮助吗?
得分 0
3条评论:
@ajcooke01 - If he does this he will void his warranty! Remember he wants Apple to replace the battery under warranty as its one of the systems which Apple posted that have a battery issue Apple’s MacBook Pro battery recall! and here's the Apple S/N checker 13-inch MacBook Pro (non Touch Bar) Battery Replacement Program
完成的
@danj Didnt say he couldn’t do that? “However I have issues with Apple and they are not fixing it free - even tough it is classified as a defective MacBook Pro”
完成的
If his system checks out with the checker then they need to do it! If the S/N is just in front of or behind the ones in question Apple often will believe they missed a run and will honor the warranty.
I've had a few systems which where just outside of the range on a different issue and time point. But, after talking to them I was able to get it done. I'll admit we had quite a lot of systems so they sorta realized it was a token they had to pay out.
As of late Apple support is trimming servicing on edge issues. I have a feeling this maybe related to the two black eye they have right now.
Left eye - keyboard issues with the butterfly's
Right eye - i9 heat issues (which is still not fixed properly) bad cooling design
@sturec22 will need to be firm and work up the food chain. The best window is Tuesday mid day to go back to the store to talk with the Apple Store service manager and then the store manager and may need to talk to a lawyer to have a proper letter written.
完成的
添加一条评论
添加你的答案
seda turec 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 455
