跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Why does my iPhone shut down (as in run out of battery) after 5 minute
Lately I have been getting a multitude of problems which includes:
Unresponsive screens
IPhone Dying after 5 minutes of being idle (much less battery life if in use - Has to be connected to a source of Power to function on a basic level)
Randomly types unwanted letters at random times
Heats up extremely easily
etc…
I would like some help for at least one, if not all, of this is possible.
Thank’s for your time
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Do you use a Mac Or PC with ti?
完成的
添加一条评论
1个答案
已选择的解决方案
Your battery is most likely at the end of its life. To be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). Anything less than 70% of design capacity will require replacement.
 Based on your description, you may also have a screen issue. However, I would start by replacing the battery first and see if that solves the shutdown issue. Then if that is solved but you still have Touch issues, then you’ll want to consider changing the screen.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Yoake 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 47
