跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A9 (2016) 是三星推出的一款智能手机。
Phone completely not responding
I have been using this phone and this morning, I restarted my phone. After restarting it, it doesn’t turn back on. Tried soft reset, hard reset and charging it. Even plugged into the computer and its not detectable. Can someone give me a solution or idea what can I do next. Please and thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi CSJ,
Sorry you’re having this issue. It turns out that your battery “may” be the issue. I found a post from 2016 that looks very similar to yours. Check it out: Phone wont turn on
I hope it helps you. Also Lithium batteries will do strange things if the “sense” circuitry is bypassed. You can either try jumping (MAY EXPLODE! - though never happened to me or mine BUT MAY!) or get a new battery (EASY BREEZY!)
这个答案有帮助吗?
得分 0
8条评论:
how do i try jumping the battery? is there a guide?
完成的
Hi again,
I personally use a lab supply. Basically a "variable battery power source!" In effect you would look for "a greater DIFF voltage."
So let's say your battery is in a protective state "DEBUG" - by jumping - (ARCing) or shorting / introducing / connecting a higher voltage to the battery. (It is possible to remove the battery from it's DIAGNOSTIC STATE- (inoperable for DUT!)
The post from 2016 is pretty spot-on! I would really consider replacing the battery for the earliest resolution turnaround.
完成的
Alright. I suppose I shall try to get the battery replaced before doing something else crazier. I'll update here once i know the issue!
完成的
CSJ,
Make sure you check the ifixit.com parts list. I recently ordered the business tool kit. All I can say is that it's 90% paid for by itself on (2) jobs!
This site is pretty much my "triage" stop for ground zero repairs. (Yes you can go ANYWHERE but I am batting 100% here on component availability alone). I just need an A1574 battery and my next job is finitto!
完成的
I had the power source tested and the power into the phone is only at 0.15-0.17 while the tech said it should be 1.00 and above. Is this true? He added and say it might be the power intake issue or motherboard.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
csjdesmond 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 634
