跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Can I make this phone water resistant?
Hello!
I was wondering is I could add something to an iPhone 6 to make it water resistant. I already have the screen adhesive strips for an iPhone 6s, but will I need anything else to make it water resistant, or is not possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
@albert8181
just because there are rubber gaskets at the Home and volume buttons does absolutely not mean it is water resistant. There are just to many areas where water will still enter your phone. I would suggest that you do not submerge it. Unless of course you do not like your phone. If you are planing to submerge it get a proper water proof case for it.
这个答案有帮助吗?
得分 4
2条评论:
Are there any things you would suggest to do to increase the chance of survival of the phone in case of accidental brief exposure to water?
完成的
@albert8181 the only real protection would be a case. Precvention will be the only proper way to protect your phone. Otherwise you are going to take a chance.
完成的
添加一条评论
Personally I think the iPhone 6 is pretty water resistant the way it is. To be fair it is not that water resistant but I have seen multiple people do water tests on their iPhone 6 (up to 1 minute under at least a foot of water) and the devices survived. Maybe someone else can provide a better answer but I think you will be OK the way it is.
这个答案有帮助吗?
得分 0
6条评论:
Would it make a difference if I have replaced the housing of the phone? I can see a gap of light coming out from the mute switch. Water would be able to get in through there. Is there a way to fix that?
完成的
@albert8181 If that is the case, then maybe a new rear housing would be a good idea. You will however have to buy new adhesive and possibly damage the waterproofing even further, so it is up to you.
完成的
Would I be able to fashion some sort of gasket to block the gap?
完成的
@albert8181 Thats a tough question. I honestly don't know, but you might just want to buy a waterproof case like ones from Lifeproof. This is about as much as I can help you. Sorry!
完成的
Thanks for helping @ajcooke01 ! I'll see what I can manage to make
完成的
显示更多的1条评论
添加一条评论
The best thing is to just get an external case which offer better protection. Altering the iPhones own case won’t do anything different than what Apple designed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 93
