跳转到主内容
加入维修社区 - 创建账户
这是一系列帮助修理洗衣机的指南和支持。
GE washer won't spin or agitate
GE washer won’t spin or agitate, it drains fine. No matter what cycle its on it will not spin or agitate. Hardwired the motor to test it and it works fine. Door switch is working fine, what else could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
@daryl23 what is the exact model for your washer and how did you test the door switch?
完成的
I just by pasted it for now but even when the washer is empty it wont spin or agitate
完成的
添加一条评论
1个答案
最有帮助的答案
Cause 1
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 2
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
这个答案有帮助吗?
得分 4
1条评论:
the belt is fine and it dosent spin or agitate even when its empty but if I bypass everything an just put power straight to the motor it spins
完成的
添加一条评论
添加你的答案
daryl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,635
