跳转到主内容
加入维修社区 - 创建账户
Insignia Flex 8 是一款由 Tianshi Digi-Lando 生产的多功能平板电脑,可以连接互联网、拍摄照片并使用各种应用程序。
I Forgot my log on pattern
How do you recover your logon pattern? I forgot mine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
insignia tablet forget pattern
完成的
添加一条评论
1个答案
最有帮助的答案
Sadly you will have to factory reset your tablet in order to be able to use this tablet again. Factory resetting your tablet will erase all data stored on your tablet.
Ensure the tablet is connected to the charger and has at least 45% battery left. If the battery dies during this process the device could be damaged.
  1. Power off the tablet fully.
  2. Press and HOLD the Volume + button.
  3. While still holding the Volume + button, press the Power button until the screen illuminates and shows Insignia.  Then release the power button only
  4. Continue holding Volume+ until one of two screens appears
  5.   A) -A screen appears with only an Android mascot in the background. If this happens simply let go of volume + and press it one time.  You should then see the screen shown in item 'B'
         B) - A list of options in the top left of the tablet screen.
Six - Use Volume - to select "wipe data / Factory reset" and press the power button to select it
Seven - Use Volume - to select "Yes -- delete all user data" and press the power button to select it.
Eight - Following the reset, the device should boot up and go through the initial setup process again as when it just came out of the box.
Feel free to ask questions!
这个答案有帮助吗?
得分 2
6条评论:
My laptop reset list is in Chinese which one is the factory wipe/reset
完成的
this won’t work for me
完成的
My screen doesn't look like that it all blue with different options and it says I don't have enough space to reset my laptop
完成的
What do I do if it says there is not enough space to reset the laptop but I can't log in to make space?
完成的
How do I reset a pin?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Cindy Snodgrass 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 8,565
