short, short, long
The display is detecting a backlight error. Check your display's power connections and restart the computer. If the problem continues, contact Apple or an Apple Authorized Service Provider.
Well Apple is not going to help you.
Lets go for the cheapest repair first, with it on, hold a flashlight at an angle to the screen and see if you can discern the desktop. If you can, replace the inverter.
Apple 6632L-0416A A1083 30 Cinema Display Backlight Inverter Board LGIT-LM300W01
UPDATE
The serial number with bar codes is located on a label under the foot of the display. To view the serial number, hold the sides of the display and gently lay the display face down on a soft, clean towel or cloth.
input that number her to identify your exact machine:
https://everymac.com/ultimate-mac-lookup...
5条评论
@mayer This might be a good one for you sir.
由 [deleted] 完成的
What are the Axxx numbers from the bottom of the stands? It may look like A1407.
由 mayer 完成的
A1083 on both displays (30 inch)
由 Perry zelck 完成的
Apple Cinema Display 30-Inch (Aluminum) Specs
Identifiers: Aluminum - M9179LL/A - A1083
由 mayer 完成的
solved : I took the inverter board form the display with continuous led (no blinking led) and put it in the display with short-short-long and works perfectly now
由 Perry zelck 完成的
