跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
313 个问题 查看全部
When I turn 3DS on, blue light appears but screen is black (has CFW)
So I was playing ACNL, then I put my 3DS in sleep mode after I was done playing. A week later, I come back to play and the screen is all black, though the blue light is still there. I figured it must have somehow froze, so I held the power button to turn it off entirely. Unfortunately, after that, every time I tried to turn the system on, the blue light appears, but the screens remain black, and I can’t actually do anything on the system. I‘m not sure what to do. If it matters at all, it does have CFW installed, but I doubt that’s the issue, as it’s been installed for about a couple years by now with no problems.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
5个答案
最有帮助的答案
Hi!
You could try the following:
  1. Remove the battery
  2. Press the power button a couple of times
  3. Plug in the power adapter. Try turning it on.
  4. Remove the power adapter
  5. Insert the battery, plug the adapter in
  6. Try to power the console on again. If it works, you’re good, otherwise I’d try the same again also with removing the SD card.
这个答案有帮助吗?
得分 7
8条评论:
Sorry for the late reply. I actually had seen someone else suggest this as well so I wanted to try it, but unfortunately the screws are stripped so I can’t actually get to the little nudge in order to pull out the battery. But the back cover itself broke off since it was kind of cracked, so I’m able to access the SD Card, just not the battery. Is there any way I can remove the screw?
完成的
I just made an account to say thank you. I was going crazy and couldn't find how to fix it, thank you so much!!!
完成的
This worked! I was about to give up hope when the wifi-chip fix only worked once, but before my eyes it finally turned on. Thank you so much!
完成的
Pranav, if you still need a way to open up your 3ds (after 4 years) you can try using a rubber band between the screwdriver and the screw, and as a last result you can drill off the screw top.
完成的
Thank you! It worked!
完成的
显示更多的3条评论
添加一条评论
I had this happen to me. I followed the steps above. I also removed the game that was inside after doing these steps, and turned it back on. : )
这个答案有帮助吗?
得分 0
1条评论:
I slapped the side of mine and it worked
完成的
添加一条评论
Thanks for the attempt to help, but unfortunately none of this worked. I may have to try and get it repaired somewhere.
这个答案有帮助吗?
得分 0
添加一条评论
This is a fairly well known bug with luma. Turn it on and leave it open and undisturbed for about 10 minutes. If it boots by then, you're good to go and probably won't have to worry about this again
这个答案有帮助吗?
得分 0
37条评论:
Do you have any advice for a 3ds that is having this problem without any CFW installed?
完成的
@standardtoad When did it start, and what were you doing with it just before?
完成的
Well, this happened some time ago and I basically gave up. I was playing some MH4U and doing the online mode when the 3ds crashed. It was able to reboot, but after I continued playing it crashed again and got stuck on the black screen of death. I then used the safe boot to try and check for updates, but I wasn't missing any and the 3ds still wouldn't boot normally, always going to the BSoD. I then checked online and tried methods like disconnecting and reconnecting whatever the thing on step 12 of the teardown highlighted in orange is. That worked for about 2-3 boots until it crashed again and got stuck on BSoD after playing some online Pokemon. Around this point, the safe boot no longer worked, since it would crash after about 2 seconds. The last thing I did which worked temporarily was the procedure mentioned in the top answer here, but it only worked for one boot and didn't work after that. As of now, the 3ds no longer boots even using safe mode and none of the methods that worked before succeed any more.
完成的
The teardown I mean is the Nintendo 3DS XL 2015 Motherboard Replacement. I have the New Nintendo 3DS XL, SNES model. Nintendo has already rejected my device for repairs, which I guess was because either the warranty expired or because I bought it from Amazon instead of directly from them.
完成的
@darthmango I don't know if this is enough information to figure out what is wrong, but the main problem that seemed to happen was that even though the 3ds was updated and had internet connection, the crashes all seemed to happen when playing games and using the online features.
完成的
显示更多的32条评论
添加一条评论
I just had this issue today with LumaCFW and I just took out the SD card, tried to turn it on a few times, put the SD card back in, then turned it on once more. Worked like a charm.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pranav Iyer 将永远感激不已
浏览统计数据:
过去 24 小时: 84
过去 7 天: 588
过去 30 天: 2,567
总计 30,551
