跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
797 个问题 查看全部
Do I need logic board silver ground strap?
There is a gap in the otherwise excellent instructions on this site in regards to replacing my iPod's logic board. What do I do about the silver ground strap that remains attached to my old logic board once I've completed all the instructions?
One post on this site says you don't need it. Another says you do.
I'm assuming I need it since, after all, my iPod came with it. I've managed to pry the old one off and attach it to my new logic board. However, it seems to me this gap in the instructions should be filled.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
+Honestly I have just changed two of the boards and did not use the ground strap and it did not cause any problems on the iPods. You are absolutely right, if and when you can get it of the old logic board, it is always wiser to apply it to the new one. Did you write a note on the instructions? That way others will become aware of it. good observation...;-)
这个答案有帮助吗?
得分 2
1条评论:
Thank you for accepting my answer and wishing you years of fun with your iPod.
完成的
添加一条评论
添加你的答案
adamorth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 2,640
