跳转到主内容
加入维修社区 - 创建账户
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Wash cycle doesn't start, not lid switch
Can anyone diagnose most likely failure, maybe electronic, if H2O fills but doesn’t wash? Shorting the lid switch wires doesn’t work. Breaker not tripped. No spin or drain either; washer giving total silent treatment!
Thanks for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@dnagofer what is the exact model number for your washer?
完成的
添加一条评论
1个答案
已选择的解决方案
Cause 1
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 170
