跳转到主内容
加入维修社区 - 创建账户
带有清脆敲击感的机械游戏键盘——全键可编程,配备 5 个宏按键。2010 年首次发布。
Slow, delayed key response?
I’ve had my Blackwidow Chroma for a year or two, but only recently I noticed that, in games, the A key isn’t responding to presses in time. It can vary, from about a half-second delay on press, to a full 4 seconds, but it’s definitely there. Does anyone else have issues with this? Is this a common problem with other keyboards? How do I change out the switch if it’s compromised?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I have the same problem but with my D key, has any fix been found for this problem
由完成的
It also happens to me but in the R key and the V key, I have cleaned it up but it stills the same I really dont know why it may be the USB port
由完成的
添加一条评论
5个答案
最有帮助的答案
Can you pull keys off? Try pulling it off and see if typing with it off works well. You can also pull another key off from a key you don’t use and put it on the A key spot, doesn’t matter. Then try pressing on it and see if it works.
这个答案有帮助吗?
得分 1
添加一条评论
Just turn off the LEDs.
这个答案有帮助吗?
得分 0
添加一条评论
It works if you turn of the LED’S as Filipi said. But the problem is the key that was lagging had been assigned as a macro key. Reset that to default and you are good to go. I dont know why this happend or how.
这个答案有帮助吗?
得分 0
添加一条评论
I have used static color and it seems to have fixed the problem. I’m not sure how this keyboard is built, but I suppose it’s the keyboard’s controller that has this issue…
这个答案有帮助吗?
得分 0
添加一条评论
recently my RAZER Macro keys of Blackwidow (M1~M5 keys) input speed slow down.
(kind window slow problem - they input funtion of M1~M5keys and there are deep delays - keep Ctrl hold kind...)
but i got a hint from these answers.
so i just turn off and back on about CHROMA color fucntion. it's fine now.
thank you guys.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Nicolson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 44
总计 12,594
