跳转到主内容
Troubleshooting and Repair for the 32" 1080P LG 32CS560 LCD TV.
Why is t here no sound
There is no sound, it is not muted and volume is turned up to 100%.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
@taulton the first thing you want to try is to use different input sources. Try coax, composite and any others. If it still does not work then you will have to check a few things. For that you will have to have some basic hand tools and a meter. Remove the back of your TV and take a good look at the boards. Check for obvious damage, like domed or leaking capacitors. Post some pictures of your boards with your question. That way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. Follow these instructions to see hwat you find. Let us know what the results are.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ruth Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 385
