跳转到主内容
加入维修社区 - 创建账户
HP Envy TouchSmart Sleekbook RT3290 m6-k022dx 配备 750GB 硬盘、6GB DDR3 SDRAM 和 AMD Elite 四核处理器。
How do I replace the battery?
Hi, I need to replace the battery to my HP Envy m6-k022dx (replacement #715050-001). There is an appendage that is attached to the battery, and connects to the computer. I want to know how to remove the appendage without damage. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I think if you are able to just root around a little bit you will be able to find the connector/appendage and then you can disconnect it with a Spudger. Just be careful to not damage it and if it does not come out with the first try keep trying and do not rush it!
这个答案有帮助吗?
得分 1
添加一条评论
There should be about 12 screws on the bottom of the laptop. Use a PH1 screw driver to remove these screws. Then use a prying tool to remove the back. Once you have the back removed the battery will be right there. Find where the battery plugs into the board and carefully unhook it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fatimah T 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 21
总计 899
