How to rebuild Front Driveshaft?
In particular - the Cardon Joint?
@jjm123 this should work for your driveline as well. Jeep-Wrangler-driveline.pdf
Let us know all the other information we need so that we can be more specific etc.
这个答案有帮助吗?
LOL - At first I had to make sure this was for a 2004 Wrangler 4 wheel drive after seeing Propeller Shaft mentioned. Not as detailed as some others descriptions I’ve found but helpful. After 140,000 miles appears the centering yoke ball has worn enough to cause vibration when shaft is installed. Thanks.
@jjm123 yeah typical original Jeep service manuals are starting to be a bit vague. Hope it works out for you!
Rep: 11
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 433
1条评论
@jjm123 how about an exact year? Engine size? transmission? What happened to your driveshaft?
由 oldturkey03 完成的
