跳转到主内容
加入维修社区 - 创建账户
Acer Aspire M5-583P-9688 诞生于 2013 年,是一款由 Acer 制造的轻薄型 Windows 笔记本电脑。
How do you replace the screen?
What is the procedure and what do I need to replace the screen on this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Touchscreen or the LCD?
With this model you should be able to pry around the displays plastic bezel and the back LCD cover.
this will allow you to get the front screen off. If you need the touch then find another one of those. There should be model numbers somewhere on it to find.
if the LCD then remove the supporting screws and then pull it up slowly. Disconnect the cable from the bottom of the LCD and then find the LCD. Should have part numbers/model numbers to look it up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jake Mancini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 592
