跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
123 个问题 查看全部
Battery drains, no water damage
Didn’t notice at first since I thought the iPad battery just needed replacement due to age. iPad was in a beautiful condition, very little signs of use, no signs of water damage nor signs of previous repairs. Replaced the original battery with a brand new good quality SMP battery. Everything works fine from what I can see, no glitch whatsoever, except an unexpected power leak of about 1% per hour. Tried disconnecting everything from the logic board except screen and digitizer, every function was disabled including wifi and localization..no change. Looked around for shorts on main lines and couldn’t find any lead, but I don’t have much experience on iPads and ZXW is not of great help with this board. Has anyone encountered anything similar before ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
maybe tristar or ios issue
完成的
In my opinion, power leak of 1% per hour in idle state is normal, with an aftermarket battery.
完成的
添加一条评论
1个答案
已选择的解决方案
1% per hour seems a bit high but with aftermarket batteries, you never really know. The problem with batteries is that making them is like baking; you apply the same recipe and ingredients but you never really know what you get until you take it out of the oven :>).
What I would do is a discharge test with a constant current load, or even better, a constant power load. Here is an example of a constant current discharge test (@ 0.1C) I did with an iPad Air battery that I suspected as being a so-so battery.
The results were pretty good and I went ahead and kept it (it was only 20 minutes shy of my benchmark). You can use a tool like this to do this test and it’s a great way to test batteries offline, perfect for checking if the new supplier is sending you good batteries.
这个答案有帮助吗?
得分 5
4条评论:
Love the oven baking analogy :)
完成的
Thanks for help. I decided to try again the old original battery that still shows about 80% capacity and behaves nicely with a different board and got the same results. It seems clearly a logic board issue, but with such small power drain I'm quite hopeless to find where the trouble is.
完成的
You might want to remove some typical offenders like FCAM/Sensor or the Home Button and then test to see if you have a longer discharge cycle.
完成的
@refectio @tech_ni Took out again the iPad from the land of the dead, thinking I might try and replace Tristar..it seems that did the trick..thanks for help.
完成的
添加一条评论
添加你的答案
arbaman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 238
