跳转到主内容
加入维修社区 - 创建账户
这套完整的家庭影院系统包含一台纤薄设计的银色 DVD 接收机,配备带多角度和缩放功能的逐行扫描五碟 DVD 换碟机、720 瓦功率放大器,并内置 Dolby Digital/DTS/Dolby Pro Logic II。它还包含五只配套的银色全频卫星扬声器和一个 120 瓦的低音炮。
won't stay powered on
this system has been in storage for 12 years. i powered it up today. the red stand by light comes on, indicating system not on. when i press any of the disc or am/fm buttons, the display lights up indicating system on, but the goes back to system off mode in a few seconds. something i’m missing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
@sarah_rver is your system a JVC TH-M303?
由完成的
yes it is. had it for 13 years
由完成的
@sarah_rver just to clarify, it turns on but after a few minutes it turns off. Any LED lights on or any sign of life when it turns off?
由完成的
添加一条评论
1个答案
最有帮助的答案
Neither the user nor service manuals provide any particular clues based upon what you have described. Therefore, I must start with the typical failure. Disconnect the speakers and try again. I expect that the unit will power up normally.
You can reference the service manual here: http://www.go-gddq.com/upload/2010-02/10...
The main power amp resides inside the subwoofer. Check to see if there is a protect light on the subwoofer.
If there is a light or the unit only “works” with the subwoofer disconnected, I would suspect that one of the amp chips inside the subwoofer is defective and further investigation is required. There are 2 large black amp-packs inside the subwoofer (STK413-400 and STK413-=430). One or both of these may be defective.
Try removing the speaker connections and report the results here.
Dan
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sarah Hughes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,319
