跳转到主内容
加入维修社区 - 创建账户
Keurig K55 可以通过型号 K55 Classic Series 进行识别。K55 于 2015 年 12 月 2 日发布,支持 K Cup 和传统咖啡粉。
No power into machine
I recently bought a Keurig K55 from bed baths and beyond. I was falsely sold this item by the sales rep. I asked if the machine would work in the uk and I was told to put a 3 pin adapter on the end of the plug and it would be fine. I done exactly this it started hearing the water and then suddenly stopped. Can I be told how to fix this and if I should use a voltage dropper convertor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @veepatel
Confirm the input voltage on your Keurig K55
there should be a label mentioning about input voltage, e.g. 110V
In UK, voltage is supplied at 230V....
If your device is labelled at 110V and you connect it to 230V, likely is could be damaged.
I think you mean step down voltage transformer (drop voltage from 230V to 110V), you need to consider on your coffee maker power consumption also. Not all converter might be suitable of this.
update us first on your current machine voltage input.
这个答案有帮助吗?
得分 3
5条评论:
I'm guessing I have damaged it. Yes the voltage is 110v. Is there anyway of repairing it?
由完成的
Hi @veepatel
Well you may try opening up and check, hopefully would be just the power supply section is damaged.
take and share some pics with us
由完成的
Sure will do when I get home from work. Thanks for ur help
由完成的
Hi please find a picture below.
由完成的
Does anyone which power supply I have to buy as in model number etc...
Thanks
由完成的
添加一条评论
here is the picture
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vishal Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 22
总计 1,138
