跳转到主内容
Repair guides and support for televisions manufactured by Sony.
750 个问题 查看全部
46XBR3 Horizontal colored lines no picture
My TV has horizontal lines blue, pink and gray lines. then it has black and gray lines. then the screen goes all black. i have to unplug it for it to stop. i unplugged all the cables and nothing. I tried hitting the back of the set and nothing. How to fix?
Update (08/26/2018)
This is what it looks like. I hope someone can help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@ritaw212
Your lines are really not exclusively horizontal. There are more vertical lines which could be caused by loss of timing. This could be a bad T-con board, bad main board or at worst a bad panel. Remove the back and take a look at the boards and the wiring. Post some images of those with your question. That will allow us to see what you see . T-con board would be my first suspect.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rita 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 70
