跳转到主内容
The Roomba Red 4100 is a vacuum cleaner robot produced by iRobot that can clean a room all on its own.
12 个问题 查看全部
I only get short or no charge in batteries
I have 6 batteries - yellow & black. The green light keeps blinking on all but 2 of the batteries.
The 2 batteries with a solid green light only charge for about ten minutes. And they only last a few minutes in the Roomba.
How do I figure out which batter IRS are dead AND is there a way to get at least the two batteries to take a longer charge?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Dan, you can try to reset the charging system. Remove the battery from the Roomba and unplug the charger from the wall and the Roomba. Hold the power button down for 30 seconds. Then try to charge it and see what happens. Of course you should also make sure that the battery is properly seated. Turn Roomba off, empty the Particle Bin, and turn the Roomba over. Remove and re-insert the battery, pressing firmly on both ends of the battery until it clicks into place. The only other way that I know off to charge the batteries by keeping it on the charger for about 72hrs even when the light is green...and if none of this works I would get some new batteries...Hope it helps, good luck to you and your Robot ;-)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,614
