跳转到主内容
The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
28 个问题 查看全部
Mcmulloch MC 1275 Black water in reservior
Is there a chemical I can use to clean out inside besides vinegar ? What about CLR
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
  • Manganese leaves brownish or blackish stains.
  • White vinegar, a weak acid, is about 5 percent acetic acid. It may remove hard water deposits from glass, rust stains from sinks, and tarnish from brass and copper.
  • Lemon juice, another weak acid, contains citric acid, which can be used in much the same way as vinegar.
  • Oxalic acid is effective as a rust remover.
  • Phosphoric acid is often found in cleaning products that remove hard water deposits.
  • Hydrochloric and sulfuric acids are sometimes used in diluted concentrations in toilet bowl cleaners. A dilute sulfuric acid is also called muriatic acid and used to clean swimming pools.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Deb’sMistake 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 228
