跳转到主内容
完整的拆卸和安装指南,支持大部分的 iPods, 包括 iPod original, mini,shuffle,nano,classic 和 touch。
6221 个问题 查看全部
问题已关闭
How to place the Front Panel Replacement correctly
I've succesfully take apart the front panel assembly but I can't place the new one correctly. The top of the screen, which is near the front camera, it is not well attached. It takes off and cannot find a a way to insert it . I guess the problem is this piece of metal http://www.skymac.com.ar/ipodtouch.jpg
Are there some tips to keep in mind?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The guides available only show the procedure to open and remove the parts do not indicate how to put the new one, and not always reassembling the device is in reverse order.
In this case, the touchscreen flex was the problem, it was folded up against the metal plate where the LCD is inserted, preventing this to be correctly seated. The cable must be placed so carefully folded so that it is right beside the front camera.
The pictures are not good just like my poor english. Somebody could put this tip in the correct guide to help others.
Thank you
http://www.skymac.com.ar/IMG_0270.jpg
完成的
添加一条评论
2个答案
已选择的解决方案
The guides available only show the procedure to open and remove the parts do not indicate how to put the new one, and not always reassembling the device is in reverse order. In this case, the touchscreen flex was the problem, it was folded up against the metal plate where the LCD is inserted, preventing this to be correctly seated. The cable must be placed so carefully folded so that it is right beside the front camera. The pictures are not good sorry.
这个答案有帮助吗?
得分 0
1条评论:
good job ;-)
完成的
添加一条评论
最有帮助的答案
macpatagon, I am not sure which iPod you have but based on the picture you attached it is an iPod touch. My best advice to you would be to study the manuals on here and see what you get. These instructions are proven and do work. As always, study the material and take a good luck at what you got. Have a clean and uncluttered work area and take your time when you do it. Good Luck
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 695
