跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly information for the second-generation Isuzu Rodeo.
2002 Isuzu rodeo it will turn over but won’t start
I replaced the fuel pump on a 2002 Isuzu Rodeo, V6 it started after I primed the fuel rail, the vehicle started up now it will turn over but won’t start, fuses check good, fuel pump comes on and vehicle has spark. Battery is new. What could cause it from cranking all the way over? been told the fuel pressure regulator could went out what do others think.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
11条评论:
@texasrebel01 you got me a bit confused. Eiterh it does turn over (crank over) or it does not. If it turns over(cranks over) but does not start then you maybe looking at a fuel issue. We need to make sure that we understand the question before we can five you some decent advice.
Rep: 1
完成的
Yes it turns over but won't start
完成的
How can engine repair
完成的
Hi @dharmahema ,
Sorry to hear about your Isuzu being broken! We can’t provide you with any repair advice right now though because we don’t know exactly what we’re working with. Please update your post to include the make, exact model, Engine size, symptoms of your problem, and the troubleshooting you’ve already tried.
完成的
I'm having this problem too! I put a new starter new battery near starter relay, but will not crank over. It only clicks. Does not crank just one click at a time/key turn. Idk what to do or try?
完成的
显示更多的6条评论
添加一条评论
2个答案
Hi
Probably i know the answer to this.
  • Probably a fuel line leak
  • or the relay doesnt work (the fuel pump relay switch)
  • And have you check the fuel pressure in the fuel line when the fuel pump is running?
  • Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
You have spark, you likely have air, and it is turning over the engine. Something in the fuel line is preventing the third fire requirement, FUEL, from getting into the cylinder.
The fuel pump is running, so it might be a regulator or something stopping th injectors.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 88
总计 3,953
