跳转到主内容
Guides and support for various television (TV) brands and styles.
9064 个问题 查看全部
How can I fix it without opening the back?..
My tv is dark all over after i spilt water all over it …..the audio is still working how can I fix it without opening the back?..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Its an lg flat
完成的
There should be a couple of numbers with it. Check the label on the back Lg......
完成的
添加一条评论
1个答案
已选择的解决方案
Teddy Mararo  you can’t! You at least will have to remove the back from your TV to evaluate the damage. This could be any board as well as the panel. If you let us know what make and model your TV is we can probably help you further, but you will have to remove the back.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Teddy Mararo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 31
