跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
449 个问题 查看全部
Swiping up, down, left, right all work. Touch does not work.
Ifixit screen 1
Ipad Original Motherboard
Ifixit screen 2
Original iPad Screen
After replacing screen, cannot select anything with touch. I can swipe but touch does not work to select anything. This is the second screen I have put in. The first only half the screen worked. This is the second screen. When I reinstall cracked original screen it works fine. Any ideas. the cables do not snap in place the same way as the original. They seem not to snap. They appear to be connected but will come off very easily.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Does the screen need to be physically attached to the base in order for the touch to operate correctly?
完成的
Michael Simonello no it does not. It will have to be properly connected to the logicboard but you can try its function even if it is not quite assembled.
You can move your screen in all directions but you can not choose the icon to open?
完成的
That is correct. I cannot select any icon. I cannot swipe to power off. I can move the screen left right up down by swiping the screen.
I also noticed that if in camera screen if i touch an area on the screen the camera focuses to that area. So something is noticing where I touch but has no effect on icons.
完成的
That is correct. I can move screen in all directions but cannot select any icon. I cannot also swipe to power off.
完成的
So it’s responding to the slide of your finger but not the tap of your finger, correct? When you turn on the device are you unlocking it with your thumbprint?
完成的
显示更多的2条评论
添加一条评论
2个答案
最有帮助的答案
Michael Simonello  this “When I reinstall cracked original screen it works fine. Any ideas. the cables do not snap in place the same way as the original” sounds like you are having issues with the connector. Yes, it is possible that you have gotten another bum digitizer but it is also possible that this is a connector issue. Worst case would be a bad touch IC. Take some good pictutes of your connectors and post those with your question. That way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
这个答案有帮助吗?
得分 1
添加一条评论
Because you asked, “Does the screen need to be physically attached to the base in order for the touch to operate correctly?“ I just assume you haven’t tried operating it without it attached to the base. You should try that and see if it operates properly because as oldtutkey03 said it doesn’t have to be attached as long as it’s connected. I have seen generic parts customers bring in they ordered themselves act up because of exposed conductive traces being shorted by the metallic body of the iPad which can usually be fixed by covering those traces with kapton tape. In most cases you can tell the quality of the digitizer by looking at the color of the traces. The higher quality digitizer tends to have smaller gold or copper colored traces and the lower quality digitizers have larger silver colored traces. If it still does not work without being attached to the base than it may not be the traces, possible defective part or could be the ultra-rare software issue, which I only bring up because you said the original works fine, to me that points away from the touch IC. For that I backup if possible and just reformat the device but I definitely wouldn’t rule out a problem with the touch IC.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Simonello 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 66
