跳转到主内容
加入维修社区 - 创建账户
Ice Maker not dumping
Ive seen a few similar questions on here but no exact answer to the problem that I have.
Samsung Fridge Freezer not dumping the ice from the tray to the holder. It makes the ice but will not dump unless i press the test button then it will turn, dump and refill.
The ice making unit is new. I had removed the old one due to a broken tray about 3 months ago so the freezer has been sitting with no ice maker and switched to ice maker lock.
The freezer is set to 2 degrees and both fridge and freezer temp work fine.
is it possible the time its been left unconnected has put some ice somewhere it shouldnt?
Can someone confirm if it could be the icemaking unit that is faulty or is it another part of the freezer not working?
Please let me know any thoughts, i will be on here regularly checking for answers.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
@darrenb what exact model is this?
完成的
here are the details on the inside of the fridge.
e-nr KA58Na40gb/06 FD8609 serial no 000229
完成的
Has it ever worked?
完成的
yes it worked fine before i removed the old ice maker when the tray broke.
完成的
would be great if someone could give me an idea on how to fix this....
完成的
添加一条评论
1个答案
最有帮助的答案
If the old one worked and the new one does not, I suspect that you got a defective unit. I’d return it and buy from a different source.
这个答案有帮助吗?
得分 2
2条评论:
thanks but is the part the part that decodes when to empty in the ice maker ? or the freezer?
完成的
the ice maker board
完成的
添加一条评论
添加你的答案
darren 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 27
总计 7,472
