跳转到主内容
Repair guides and support for Panasonic's Viera line of televisions.
How to address the 7-blink code?
Mine is a Panasonic TC-P42ST30, photo attached. It had the 14-blink code. I replaced the P, A, SN & SS boards per advice from related topics. Now it has the 7-blink code. What am I doing wrong?
What next?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
mchlgrblsk  the 7 blink code is still related to the SN board
Driver SOS2
(SN Connector DET)
(SN Scan and Logic IC)
take a look at your connection (connector) and double check your work.
The 14 blink code was IR LED SOS and should have originated from the A-board only. not sure why you repalced all the boards.
这个答案有帮助吗?
得分 2
6条评论:
Background is here: Black screen, 14-blink error code
I don't think I have the knowledge to understand your answer, e.g. what is "Driver SOS2"? SN Connector DET, SN Scan and Login IC - are these elements I should look for on the SN board? Or are you saying to just check all my connections?
完成的
mchlgrblsk those are the reasons for the error code;-). Basically what the manual is telling us is to check the SN board connections etc.
完成的
Aha, will do, thanks!
完成的
Update: swapped out the new SN board for the old SN board, got 14-blinks; put the new SN board back in, checking connections carefully, got 7-blinks; then disconnected ribbon cable and power cable to SN board, got 8-blinks.
What does it all mean?
What else to do?
Is there some specific element I can test with a multimeter?
完成的
mchlgrblsk 7 and 14 blinks are the SN board 8 blinks are:
Unit is dead with 8 blinks power LED.
Cause: Defective SS board, part number
Take a good look under the board. It is known to shorten out the the chassis where the mounting screws are. Check for arcing marks on the board as well as the chassis where it mounts
完成的
显示更多的1条评论
添加一条评论
添加你的答案
mchlgrblsk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 1,475
