跳转到主内容
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
80 个问题 查看全部
Rough idling, rough running, loss of power, poor fuel economy
Truck idles rough after start and continues to do so while driving. Bad vibration. Loss of power, hard to maintain highway speed. Very poor gas mileage.
My attempted fixes have been.
  1. New fuel filter
  2. New spark plugs
  3. New plug wires
  4. New timing belt
  5. New serpentine belt
  6. Tried Sea Foam system cleaner
  7. Tried Chevron fuel system cleaner
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@bangbangtrs
this could be lots of things from a bad MAF, bad crankshaft position sensor to a cam positions sensor and many things in between. I would suggest that you get the OBD scanned and see what codes your truck shows. At least then you have a starting point. You also want to let us know the exact year and engine size for your truck.
这个答案有帮助吗?
得分 1
2条评论:
Thanks so much for responding so quickly. I was in such a rush I completely forgot to add engine and year. It's a 1999 Ford Ranger XLT regular cab 2wd with the 2.5 liter 4 cylinder. Funny thing is that the check engine light is not on. Can I still use an OBD if it's not lit? Thanks again.
完成的
Yes you can. Not every code trips the check engine light.
完成的
添加一条评论
添加你的答案
Todd Soderbeck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 468
