跳转到主内容
Repair and device guides for the 2016 Samsung Galaxy J5 smartphone, model SM-J510FN.
74 个问题 查看全部
I dropped my phone in the bath and now my data (4G) wont work properly
The question basically sums up my problem, but does anyone know how I fix my data after dropping the phone in water? It still works slightly. I have to have a spectacular connection (full bars) for it to work at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@tegan_ricara
if you continue to use it, it will stop to “still works slightly” pretty quickly.  You have a water damaged phone and are running risk to further damage it by using it.
Remove your battery and you’ll need to disassemble your phone. Use something like this guide Samsung Galaxy J5 (2016) Disassembly but it starts at the end of the disassembly. Once you have it disassembled you need to clean it. Use this guide 修复iPhone 的进水故障 for that. It was written for an iPhone but all the points still apply to your phone as well. Once it is properly cleaned you want to go ahead and repalce the battery. Reassemble your phone and then re-evaluate. Only after a proper cleaning can one make teh determination what may have failed. yours appears to be an antenna/RF issue and may require the help of somebody who specializes in board level repair.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
Samsung Galaxy J5 (2016)图片
指南
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tegan Ricara 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 259
