跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
Cracked Case that holds the screen
Hi all:
I have a mid 2009 MacBook A1342. The case that holds the screen is starting to crack at the hinge point. Has anybody seen this problem and is there a repair solution?
If possible, I’d like to replace the part (I don’t even know what’s it called) vs. slapping some glue on it.
Thanks in advance,
Glenn
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@pokeyonabike
not sure if you are talking about the clutch cover or the lid cover (check on here and step 21 on here MacBook Unibody Model A1342 Right Clutch Hinge Replacement
Eitehr way, yes it can be replaced. Post a couple of pictures of where your damage is and what it looks like. That way we can see what yuo see. Use this guide 在已经存在的问题里加入图片 for that
MacBook Unibody Model A1342 Right Clutch Hinge图片
指南
难度:
困难
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 2
添加一条评论
Hi Oldturkey. Thank you for responding. Below are the pics of the cracks starting on the top clamshell that holds the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Glenn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 167
