跳转到主内容
加入维修社区 - 创建账户
Durango 被定位为一款坚固的卡车底盘 SUV,旨在容纳最多七名乘客,并在适当配置下可拖拽重达 7,500 磅(约 3,400 公斤)的负载。
Help! 2000 Durango No crank no start no bus whats wrong?
Why does my 12v light tester light up when i go from battery ground to fuse box ground? Im wondering why i have a no crank,no start on my Durango so i traced all wiring from ignition switch to starter problem seems to be at ground wire from fuse box to alternator i think and i replaced starter relay and it doesnt switch on when i crank it. Also showing No bus please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@mf808kailua
do you have anything? Any headlights? Do you have power to the starter? Let's slow down with the testing since it is a bit confusing as in what and where you test. Check to make sure that you have overall power. Turn your headlights on and try to start. Do you have anything? Do the lights go dim? Make sure you start with a known-good battery.
这个答案有帮助吗?
得分 1
6条评论:
Battery is good all lights work..headlights dont dim when i crank it and there is power at starter. My ground from fuse box is making my test light go on when i go to battery ground isnt that bad? And it seems my trigger wire to starter isnt showing any response when i crank it also tested it with multimeter. Could any of those 2 things be it?
由完成的
Also my test light goes on from battery positive to engine block when key is in on position thanks again for your reponse
由完成的
@mf808kailua your test light should not come on when you go from ground to ground. Double check on where you attach it to the fuse box.
由完成的
I did and im touching battery negative to negative on fuse box which i believe runs to the alternator /block ground?
由完成的
@mf808kailua if your testlight comes on when touch ground-ground you have a short somewhere. pot some images of where you connect your light so we can see what you see 在已经存在的问题里加入图片
由完成的
显示更多的1条评论
添加一条评论
添加你的答案
Marcus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 30
总计 2,962
