Replacement glass for popcorn machine
Need a glass window on the popcorn machine replaced
wclilmom you forgot to tell us the make and model of the popcorn maker. If you can’t find a direct replacement any good hardware store can guide you to a glass or mirror shop etc. that can fit your glass. Post some pictures of the frame and the popcorn maker with your question. We may have more ideas on how to fix it. Use this guide for that 在已经存在的问题里加入图片
这个答案有帮助吗?
Hi @oldturkey03 ,
Just wondering if temperature rating, thickness etc may be a consideration in what type of glass may be used in this machine?
Hi @jayeff that would really depend on the model of the popcorn maker. If it has a kettle in the middle of the maker it may not, depending on the distance to the glass. As always, anything is possible.
@jayeff 1/8 inch
my glass in my popcorn machine has been broken. what type of glass can I use regular glass or plexiglass?
@Venessa Pettway
I'm not sure about plexiglass.
Looking at the specs for plexiglass, it can only withstand temperatures of 320°F (160°C) so it may depend on how hot the popcorn maker gets etc.
Perhaps it may be better to consult a glazier about it.
The glass of my popcorn is broken. I need to replace it. My question is do I need heat resistant glass or just plain window glass?
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 30
总计 1,706
1条评论
Olde midway 6oz P600/P650
由 Earlene Martin 完成的
