跳转到主内容
加入维修社区 - 创建账户
配备 CD 播放器、带 AM/FM 调谐器的接收器、MOSFET 放大器、带 14 位单行 LCD 显示屏的可拆卸面板,以及遥控器。
Why does Bluetooth keep pausing with pandora
Be playing fine then pause
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Pandora and Bluetooth can sometimes be finicky when used together. Pandora updates their service often, and that occasionally wreaks havoc on the Bluetooth connection, especially for car stereos. Here are a few things to try:
  1. Make sure you’ve got the latest version of Pandora software - check for app updates.
  2. Make sure you’ve got the latest version of OS on the device you’re running Pandora on.
  3. See if there’s a firmware update for your JVC car stereo - there probably isn’t but you can check on JVC’s website.
  4. Use the USB input on your JVC car stereo instead of Bluetooth - the USB connection is likely to be much more stable and trouble-free. Most JVC car stereos will let you keep the Bluetooth connection live for making calls even when you’re using the USB connection for streaming music.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
aaronnewman33 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,312
