跳转到主内容
加入维修社区 - 创建账户
关于 Fujifilm X20 的一切。
Refuses to turn on
For some reason my X20 will not simply turn on. I have charged the battery still nothing Help please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Have you tried pressing the play button to turn it on?
这个答案有帮助吗?
得分 0
1条评论:
Hello Andrew 6, I have same problem and when I press play button it starts playing the photos but the switch is of. If I switch on it will not do anything, could it be this fuse? Thanks in advance
由完成的
添加一条评论
I’ve had exactly the same problem on my X20. I followed the disassembly guide and traced the fault to a blown fuse on the main board, a tiny SMD fuse in 0603 package. I believe this is rated at 2.5A. I’m going to replace it and if it works I will add a replacement guide. Hopefully there are no follow-up faults.
Update (05/14/2020)
I’ve replaced the fuse on the PCB and reassembled the camera - it is working absolutely fine now! I've added steps to the disassembly guide to show where the fuse is located.
这个答案有帮助吗?
得分 0
1条评论:
Where is this fuse located? Is thid fuse easily available?
由完成的
添加一条评论
添加你的答案
Angus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 29
总计 1,358
