跳转到主内容
加入维修社区 - 创建账户
Apple 带线控和麦克风耳机的维修信息。2009 年发布。型号:MB770G/B。
Right earphone not working
Hey guys! My right earphone isn’t working and if I pull slightly on the wire near the ear it suddenly starts working. Please can someone help me how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
kill or cure lol :)
just open it up if u can solder, and glue it back after it`s a 5 min job
这个答案有帮助吗?
得分 1
添加一条评论
When this problem occurs at the jack plug end it's usually relatively straightforward to chop off the plug and fit a new one, but at the earphone end it's much harder.
If you can hold the wire in such a position that it works, you might be able to mould some Sugru (sugru.com) around it to hold it there, but it might not last long. Otherwise you'll have to try and crack open the earpiece in order to pull the wire beyond the break into the housing and re-solder. But it'll be kill or cure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maaheen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 685
