跳转到主内容
Why is my MacBook battery condition so poor after recently replaced?
I have a MacBook (13-inch, Aluminum, Late 2008) I got the battery replaced around 1month ago and when you click on the percentage the battery condition shows service battery, it only has 29 cycles. Anyone know why the condition is so poor even though the battery was replaced recently and has a low number of cycles. This is the battery information from the system report.
Battery Information:
Model Information:
Serial Number:
Manufacturer: DP
Device Name: bq20z95
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 0
Hardware Revision: 0
Cell Revision: 0
Charge Information:
Charge Remaining (mAh): 409
Fully Charged: No
Charging: Yes
Full Charge Capacity (mAh): 1441
Health Information:
Cycle Count: 29
Condition: Service Battery
Battery Installed: Yes
Amperage (mA): 767
Voltage (mV): 12082
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Who’s battery did you get?
I would review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure you're using the correct charger and the MagSafe chargers cable and connector are in good shape, also check the systems connector too.
这个答案有帮助吗?
得分 1
4条评论:
The brand of the battery is RoHs, it was never used.
完成的
@ronaldofrity Rohs just indicates compliance to a directive about dangerous goods (https://en.wikipedia.org/wiki/Restrictio...)
If full charge capacity is 1441mAh as indicated, it is a faulty battery that needs replacement. Even an iPhone's default battery capacity is above that.
完成的
It used to be in good condition but became in such poor condition in less than 30 days. Any reason why it might have died down so fast.
完成的
Where did you buy it?
You need to get a replacement. Otherwise you'll need to buy another, this is a defective battery.
完成的
添加一条评论
添加你的答案
Ronaldo Frity 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 121
