跳转到主内容
加入维修社区 - 创建账户
型号 A1418 / 2014 年中 / 1.4、2.7 及 2.9 GHz Core i5 或 3.1 GHz Core i7 处理器
iMac CPU + Ram Upgrade Compatibility
I am looking to upgrade my Mid-2014 iMac. It currently has a core i5 1.4 GHz processor and 8GB of DDR3 ram. I have found a kit of 16gb of ddr3 ram, but I don't know if it is compatible: http://www.crucial.com/usa/en/ct2k8g3s13...
I was also looking to see what the maximum compatible CPU that the iMac is able to handle that is also under $250.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Got some bad news :-{
Your system has a soldered in CPU so it can’t be replaced, to add to this your RAM is also soldered in!
Here’s the IFIXIT logic board replacement which you can clearly see things iMac Intel 21.5" EMC 2805 主板更换
Sorry
这个答案有帮助吗?
得分 4
1条评论:
thank you!!!
由完成的
添加一条评论
添加你的答案
Armaan Bassi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 35
总计 4,407
