跳转到主内容
Repair guides and support for televisions manufactured by Sony.
748 个问题 查看全部
Black screen, with slow flashing white LED
I have this exact issue, I have replaced all boards, Main video, power board, and T-conn, but i'm now stuck where this question left off. Black screen, with slow flashing white LED. My tv is the XBR65x850C, but having the exact same issue.
Started with not powering on,
replaced power board, nothing,
replaced video board, LED flashed amber/green
Tried to update via USB with latest firmware from sony website,
Now still a black screen with slow flashing white LED.
I'm hoping its not the panel now since I don't have many options left. Any help on this would be great!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
We need Sony to give us the check list they have for the order process for each light code, thats what we need, some body out there who worked for these Sony people, and quick them, that know all the pros and cons, theres alot of us having this same issue, and there not helping us by telling us to buy there new and in model, problems fix, come spend another 1000 dollar bill, and eat your old tv we sold you, what ever happen to Zenith, when tv lasted 15 to 20 years,
Someone is holding the cards out there, if they have a heart or soul they would have mercy and tell us who spent hard cold money {in debt} still paying on this Sony defect, found me an old tube tv some one put out in the trash to use, Oo the year on this Tv 1991 philco, what we mess USA made. i got it out now, now i can start living again. Sorry James thanks for telling us you bought all the boards to try to fix your tv and i to were about to do the same thing until i saw your message, some day, ill set mine aside until until we finally get the right answer, Thanks
完成的
Sony XBR55x850c tv has same issue
no picture and the white light keep flashing for ever
dim white light keep flashing every 10 second.
完成的
What I should do
完成的
Did you ever fixed the 10 sec white light?
完成的
I have an XBR-65X850D at first i had picture but had fuzzy horizontal lines so i changed the Tcon board but now it shows a slow blinking white light then a dim white light but still no picture just a black screen not even back light is on. I’m really hoping this isn’t the panel is there something I’m missing?
完成的
显示更多的1条评论
添加一条评论
3个答案
已选择的解决方案
James Mckinney
you really do not have a lot of options left. You mentioned a firmware update but did not tell us why or how it ended up. Also, you are certain that your replacement boards are all good. if you still have the old board, try the old main board and see what your led shows. Your TV should have a Smart Core Red LED that should have started to flash a pattern which would have identified which board is failing.
It is possible that this is the panel itself but I would go through all the checks for the power situation as suggested by the sony fault finding flowcharts.
Fault-finding-flowcharts.pdf
Here are the steps to take for the software updates for the B-Board and the T-con board. See if these will work for you.
这个答案有帮助吗?
得分 3
16条评论:
I received the amber/green light only after replacing the Video board, i went ahead and replaced the T-con board as well being unsure what the amber/green actually meant. After still recieving the amber/green light, I tried updating the tv, plugged the USB in, the light sequence changed to a blinking white LED, which seemed to mean updating. My USB stick also has a Red LED built in when it is being accessed. Updating took quite a while before the White LED went from a steady flashing white, to a slow dim, in/out. Thats where the TV is at now. Turning the tv on/of, plugging/unplugging just results in the slow dim on/off. No picture on the screen just the dim LED. I'll try your suggestion and use the old board.
完成的
As far as i am aware the boards are good, just ebay replacement stating 100% tested and working. Though i have the tools and parts, my knowledge on actually fixing the tv is minimal. Even figuring out the Multimetter took a little time. As far as the "smart core Red LED" goes, i'm not sure what that is or where to look. From the inital problem the TV LED was dim lit white,black screen, (replaced boards, amber/green-blinking white-dim flashing white)Still no screen. Thanks again for the help, i'll try to decipher the flow charts and see where it leads as well.
完成的
since your LED is white it appears as if part of the roblem could be the update for the boards.
完成的
So I've tried putting the old Video board back and there is no LED illumination at all, Replaced with newer board and the LED illuminates, but its a light white to dim, then off and restarts. Its almost like a power loop, but I'm not 100% sure This White LED reboot sequence only started after I tried to update the firmware per USB. Prior was a the amber and green blinking light. Still no picture throughout all of these changes.
完成的
I thought it was just a reboot due to the update malfunctioning, but after attempting to factory reset the tv, the reboot continues to happen throughout the reset as well. So i'm guessing its something internal causing the TV to reboot. I've tried putting the old Power and Tcon boards back, but the problem still persists. I'm at a loss.
完成的
显示更多的11条评论
添加一条评论
I just received a replacement main board and was running into the same problem. I think I just fixed the tv. I unplugged the tv, plugged in the usb with the firmware on it, and hooked up an ethernet cable to the tv. When I plugged in the tv the amber/green lights flashed for about 10 minutes, then it changed to a slow pulsing white light for another 10 minutes, then SONY appeared on the screen. It rebooted once, and then a message appeared telling me that the update was complete and to remove the usb.
这个答案有帮助吗?
得分 1
1条评论:
I have same problem. TV keeps turning on and off with white light slowing turning. I tried USB filmware update. ( Plugged power, ethernet cable and than USB). Nothing changed. Keeps on turning on/off ..Sony logo comes up and shuts down. Does someone have a solution how to fix this issue.
完成的
添加一条评论
Did you ever solve the problem? I am having the same issues. I’ve replaced the power board and main board, but still only get the white flashing LEDs from the remote. At a loss as to what to do next
这个答案有帮助吗?
得分 0
1条评论:
yes i did and i have also made a video https://youtu.be/PqTedRUGr44
完成的
添加一条评论
添加你的答案
James Mckinney 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 14
过去 30 天: 85
总计 18,547
