跳转到主内容
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
What is causing these lines on my iPod's screen?
My issue is similar to the one that Why do I have a gray horizontal line on my screen? had, but was never completely resolved. There is another interesting fact about this problem that I didn't see mentioned there.
My iPod Classic has lines that go across the screen, but that disappear once the screen fades (not completely asleep). I squeezed different areas around the LCD as per one of the answers to the similar question, but nothing changed. The most odd part about this problem is that sometimes the lines extend along the width of the screen shorter or farther than others if I reset the iPod or after leaving it on the charger for a while.
Could this problem be a connection, a component on the logic board, or even the LCD itself? == Update ==
The lines magically disappeared. Not even joking. I didn't touch my iPod over the weekend, and when I grabbed it to go to the gym this morning, the lines were gone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
hi david i can get the lines off my ipod 5s why that plz hep me because i need it fix soon plz message me back
thnks from charmaine12
完成的
hello, i have to this kind of problem but after some time they are no more why this happened?
完成的
添加一条评论
4个答案
已选择的解决方案
David Hodson, I would definitely change the LCD. Even if it is the connection or the connector , this would be resolved during a change. Just clean your connector when you replace the LCD. It is also a lot cheaper than the logic board. I think that the difference in the lines is caused by a difference in current that the LCD received and therefore the appearance changes. Good Luck...and as you probably know, it is a bear to open :-)
iPod Classic Color Display
iPod Classic Display Replacement
Replace a broken or damaged 2.5" (320x240) LCD display compatible with an iPod Classic with color display.图片
产品
$29.99
这个答案有帮助吗?
得分 3
2条评论:
+ Sounds good to me, Turkey. If I get around to replacing it and noticed that it's fixed I'll come back and accept your answer.
完成的
It's better to replace the display and clean the terminal
this will fix the entire appearance.
完成的
添加一条评论
yep. i had same problem. lines getting more and more, worried that it would eventually take over the whole screen, looked into getting screen replacement but the lines have basically gone away now and are constantly going away more
这个答案有帮助吗?
得分 1
添加一条评论
In my opinion it would be better to clean the display terminal this would fix the problem rather than replacing the logic board .
I faced similar problem a month ago and I was successful when I cleaned the display terminal with a light solvent(VCR head cleaner)
这个答案有帮助吗?
得分 0
2条评论:
Where is the display terminal?
完成的
the display cable is just under the hard drive
完成的
添加一条评论
Hi if u maybe hit the back of ur iPod it could cause it do that some times if u do that a few times u probably will have to get a screen replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Hodson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 118
总计 35,078
