跳转到主内容
加入维修社区 - 创建账户
戴尔于 2016 年末推出的 15 英寸笔记本电脑。这款笔记本的可配置性很高,采用第七代处理器,配备灰色塑料机身。
Why do I keep getting this alert?
Every time I open my computer, I get an alert that states
“Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust the performance to match the power available.
Note: This warning can be disabled in BIOS setup.”
I have gone to BIOS setup multiple times and it still comes up. My battery no longer charges, but my computer says it’s healthy. My computer is also running very slow, which is annoying. What else can I do in the BIOS setup to fix this problem and make so that my performance isn’t hindered?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I have the same issue. I am using the original charger. Also when this started the laptop began operating slowly.
由完成的
添加一条评论
2个答案
已选择的解决方案
Use an original Dell charger on your laptop.
Using aftermarket ones or different model chargers that are not compatible will cause the laptop to only run on wall charger but not charge the battery.
这个答案有帮助吗?
得分 3
添加一条评论
I had this same problem within a year after purchasing my Dell 15 5567. A new Dell charger didn't fix it. Luckily laptop was still under warranty and sent it to Dell and they replaced the system board. Now 5 years later laptop has same issue again and not under warranty however it turns out the charger was bad this time(verified this by taking my laptop into an electronics store that sells Dell laptops and plugged in the charger powering the display model and it started charging). Also I bought a generic charger and it works fine(Insignia brand from BestBuy).Symptoms of the charger going bad was having to unplug/plug in cord multiple times or twist the connector in the socket until it started charging.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rosalie Severson 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 39
总计 2,617
