跳转到主内容
500 series DSLR camera developed by Nikon. Released in February, 2011.
doesn't fully shut off (coolpix b500)
hi,
so my Coolpix b500 (they didn't have that in option) isn't shutting off properly, when i shut it off the green light still is on and the battery's die soo fast! (I use lithium) I have check every setting and have looked on the internet but I cant figure out how to fix it!
please help!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Where is the solution to this problem?
完成的
添加一条评论
1个答案
已选择的解决方案
I have this issue too. What I do is turn it off, put the lens cap on then turn it on. A message will come on the screen to turn it off then on again. Once I turn it off this time the light goes out. Hope this helps
这个答案有帮助吗?
得分 2
4条评论:
I have done this before but wasn't sure if it was okay for camera and if it fully shut off, thanks!
完成的
Thanks Karen. I was having the same problem but your solution fixed it. Thanks again.
完成的
Well done…troubled me for ages…works! Thank you..
完成的
This method seems stupid to me. To use an error action to make the light go out. What does Nikon say to do to get the green light to go out when you shut the camera off. That should do it on the B500.
完成的
添加一条评论
添加你的答案
heusscarolyn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,805
