跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Possibly received bad battery...
I just replaced the battery in an ipod video with a new one provided by you. The repair went smoothly - I've done this before with other ipods using your fine replacement materials and instructions . It works fine when I plug it in to charge - all the music is available and plays without a problem. As soon as I disconnect the charger, however, the ipod goes dead and cannot be booted. If I leave it on the charger, the little icon comes on saying that it is charging, but even after many hours, it does not charge.
Do I have a bad, new battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You can try a new battery but first, I would make sure that the cable for the battery is connected to the logic board correctly. Lift up the connector to the batter flex cable, then remove the cable. Make sure the contacts are facing the correct direction. Use this guide to help: iPod第五代(视频版)电池更换 Make sure the brown clip for the battery's cable is pressed down all the way. Once you have tried this, see if the battery will allow the iPod to turn on. If it doesn't, you may have a bad battery or have damaged the battery connector on the iPod's logic board. That is the little brown connector that the cable goes into. Let me know in a comment if you need any other help. I have been working on these for a very long time. :)
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
bcohan, my first instinct would be to say yes. Now I do know that the 5th gen has had issues with the charging circuit and some coil problems. I suppose for the few dollars for a replacement battery, I'd go that way first. If you still have problems after that, you may have to take a closer look at the logic board. Good Luck
这个答案有帮助吗?
得分 1
2条评论:
I replaced that battery because mine would die after 2 minutes. Now I have no battery power at all, so I redid the repair, and got the exact same result- no battery power even after 8 hours of charging.
完成的
Did you check to dock connector on the bottom of the iPod? Check for bend or corroded pins and also for dirt & debris. Do you get anything when you plug it into your computer? Is it recognized at all?
完成的
添加一条评论
添加你的答案
bcohan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 721
