跳转到主内容
加入维修社区 - 创建账户
Garmin Nuvi 255W 是一款 GPS(全球定位系统)设备。
keyboard not working properly
When I'm trying to enter an address, the right side of the keyboard is off by one key (e.g. J becomes k). Lately, the only thing that works is "Go Home." Will replacing the screen correct this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I found the following and it worked, though I did have to do it several times.
Here are the instructions to do the recalibration of your keyboard.
1) Turn off your Nuvi
2) Press and Hold the upper left corner of the screen and at the same time turn the unit on.
3) When you see the screen appear, release the power key, but keep touching the screen.
4) In about 30 seconds, a screen should appear that says "press the dot", and 5-7 dots should appear around different parts of the screen. Press each dot as it appears.
After the calibration is done, you should be taken back to the main screen. From that point TEST the different keyboard keys and they should work better. If not, try again.
https://www.justanswer.com/gps/5jhpw-gar...
这个答案有帮助吗?
得分 1
添加一条评论
you might be able to calibrate it from settings,or just by a factory default
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ellen Houghton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,829
