跳转到主内容
car starts off slow and good after. code P0962 . replace how?
I have a 2003 honda accord coupe, no leaks in the transmission at all. When I start to drive the car it takes a lot to get going but after if moves just fine. No problem in shifting and the reverse is good too. Is it the pressure control solenoid valve?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Dexter Murphy, error code P0962=Pressure Control Solenoid A Control Circuit Low. Had the same happening on my jeep and required me to replace the Solenoid. There is a great flow chart fault finder on here I know it does say civic but the error is the same :-)I also attached an image for the transmission and the solenoid is shown as #4 and sits on the outside of your transmission. Good Luck and I hope you get it done.
这个答案有帮助吗?
得分 2
2条评论:
Thanks oldturkey03 for all your help. I get the part in tomorrow. I pray this is it. Have a great day
完成的
thank you for accepting my answer and I hope that you get your error code resolved with the new part. BTW my jeep had the same error code and would not shift gears and drove horrible, after changing a $40 solenoid inside the tranny, drives like new. So we'll keep our fingers crossed...Good Luck
完成的
添加一条评论
添加你的答案
Dexter Murphy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 40
总计 8,735
