跳转到主内容
MacBook Pro 17 inch screen goes blank 2 minutes after booting up
MacBook Pro 17 inch screen goes blank 2 minutes after booting up.
I replaced the battery and the charger, still no results. I replaced the logic board, still no results. Tested booting up with both Memory sticks and then individually, still no results. Please advise.
V/R
Stan J. Dominick
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It might be the inverter board..the age of the Mac points to that and with the logic board already changed I believe there's not much else to be tried. Here you have a guide to the inverter replacement:
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display Inverter Replacement
这个答案有帮助吗?
得分 2
1条评论:
To see if this is correct, when it goes out hold a flashlight at an angle to the screen and see if you can discern the desktop.
完成的
添加一条评论
添加你的答案
Stan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 56
