跳转到主内容
加入维修社区 - 创建账户
雪佛兰科鲁兹是通用汽车公司雪佛兰分部生产的一款紧凑型轿车。科鲁兹于 2008 年首次发布,采用前置发动机、前轮驱动设计。
ODB2 give error P0136
There is two errors appear when i read ODB
  1. P0136 O2 Sensor circuit bank 1 sensor 2 (current fault)
  2. P0136pd O2 Sensor circuit bank 1 sensor 2 (undetermined fault)
Where i can find the o2 sensor 2 in the bank 1? and how can i fix this error?
My car info: Cheverolet cruze 2012, 1.6 petrol
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
As your car is a 4 cylinder it only has bank 1 . It does have sensor 1 and sensor 2. Sensor 2 will be the O2 sensor behind the catalytic converter in the exhaust system . replacing the sensor will probably fix the issue however its always a good idea to check the wiring around the sensor as they have been know to get burned by the exhaust pipes. when reinstalling the new sensor keep the wires clear of the pipes . This site will help with understanding the O2 system
https://www.aa1car.com/library/oxygen_se...
Hope this helps
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Abdul kader Zein Eddin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 2,381
